Got my 5.3 where to start
Hi guys new to the site got a 5.3 out of a 03 avalanche 92xxx miles got it for $335 this thing is clean!!!
Plans for it is to be street strip motor 400 at the crank is the goal where do i start what cam, heads, going to be using an ls6 intake what injectors should I use anything else I need? Sorry for all the ?s but im new to lsx's and motors in general ive swapped heads, intake, and carb on an older sbc and no I dont want a shop to do the work I want to learn
So far ive already stripped off the accessories, exhaust manifolds, intake, cleaned the valve covers this is going into a 3rd gen camaro Ive done the research on what I need for it to fit so got that part covered
car craft magazine tested every factory lsx cam in a 5.3 and the factory ls2 cam made 400 hp 400 tq at the crank ! you can get factory cams pretty cheap around here. but they is a lot more power to be had from a aftermarket cam
straight from the Magazine. cam only swap
Baseline 5.3L LM7 Made peak hp 353 @5200rpm Peak TQ 384 @4300rpm
LS1 Cam in the 5.3 LM7 Peak HP 382 @5500RPM PEAK TQ 389 @4800RPM
LS2 Cam in the 5.3 LM7 Peak HP 403 @6100RPM PEAK TQ 399 @ 4900RPM article said this was the only cam they had valve float with past 6100rpm
LS3 Cam in the 5.3 LM7 Peak HP 405@ 6100 RPM PEAK TQ 398 @ 4900RPM
LS6 Cam in the 5.3 LM7 Peak HP 376@ 5900 RPM PEAK TQ 389 @ 4500RPM
LQ9 Cam in the 5.3 LM7 Peak HP 376 @5900RPM PEAK TQ 389 @4500RPM
L33 Cam in the 5.3 LM7 Peak HP 362 @5300 RPM PEAK TQ 387 @4500RPM
LS7 Cam in the 5.3 LM7 Peak HP 422 @6300RPM PEAK TQ 395 @5000RPM
LS9 Cam in the 5.3 LM7 Peak HP 420 @6200RPM PEAK TQ 393 @5100RPM
LSA Cam from the SC CTS-V in the 5.3 LM7 Peak HP389 @5600RPM PEAK TQ 394 @4800
here are 3 custom cams they tried also !
duration 200/200 Peak HP 380@5400RPM PEAK TQ 401 @4700RPM
duration 210/218 Peak HP 411 @6000RPM PEAK TQ 406 @4700RPM
duration 224/232 peak HP 442@6200RPM PEAK TQ 412 @5000RPM
I hope this helps !!!! of course they changed the springs out to accommodate for the higher lift cams. you can get those factory cams cheap on here.
