Need assistance on selecting injectors
Old 06-07-2013, 10:27 AM
mjones2004a's Avatar
Default Need assistance on selecting injectors
Hey guys doing a motor swap in my chevelle... it will be a 6.0 for to a 370ci will have ported vic jr intake with accufab 4150 tb .. i will be using the edlebrock fuel rails. Just not sure what injectors i need as this is the firts time i have messed with the LS stuff.. i am expecting 450-475hp (hopefully) to tires and will have a fogger on it spraying 250-350 on top .. Any suggestions or advice would be appreciated.
Thanks Mike
Old 06-07-2013, 12:08 PM
cmac06's Avatar
You need LS1/6 style long (60mm, 14mm o-rings). Connector is based on harness Ev1 is standard for ls1, but later harnesses use Ev6; but there are adapters available to switch from one to another.
Old 06-12-2013, 05:01 PM
hoagieroll's Avatar
You might check out DeatschWerks injectors. They've got a pretty good selection of LSX specific injectors along with a universal Bosch EV14 line. www.deatschwerks.com
Quick Reply: Need assistance on selecting injectors
