electric help!!!!
electric help!!!!
in my trans 2000 my radio just shuts off and when it does I lose power to my windows at the same time. once it cuts back on everything is back to normal. some days it don't do it and then it has its days its non stop for like 30 min. I try little things like hitting the dash or side of the middle console and it does the trick... what can it be. it even does it wit an aftermarket radio
Copy & Paste Moderator
BCM solder issue:
https://ls1tech.com/forums/stereo-el...der-issue.html
https://ls1tech.com/forums/stereo-el...lickering.html
Images appear to be missing from the first page of "The Fix" thread that Blu99T/A posted, but you can see a pic of the BCM and the affected solder points circled in the other thread above.
