cam
cam
Poss got good deal on a cam. Specs are @.050; 223in 231ex .638 in .644 ex lsa is 120 icl is 120. How will this cam act in a 11.0:1 l92 headed lq9 with f/i and a 2800 yank converter and a 3.42 rear with the 4l65e?
Would really suggest you use the Internal Engine forum section..
You would likely have to give more specific information.. is this an off the self cam or a custom grind ?.. what brand name is it ?.. type of cam lobe profile... etc..
120 degress is pertty large LSA.. but I'll defer to the engine/cam experts.. I can help you on swapping the LQ9 into something tho !
with that lift, you better verify that you have proper ptv clearance!
LQ9 has the flat top pistons
You didn't specify what head gaskets either ( compressed thickness?)
Also, as said before, that is a large lsa @ 120 sounds more like specs for a boost application, rather than N/A
just a example 68' Camaro 6.0L T56 w/ 4.10 rear gears
I am running a iron block 6.0L w/ LS2 rotating assembly (stock flat top pistons), LS3 heads. GM mls head gaskets .054"
custom grind spec'd cam: 226/234 .629”/.629” 113 LSA +2 advance
my pistons are fly cut on the intake side
Just because it may be a "good deal", doesn't mean that it will be "good" for your application
