HSW 90mm plate with stock throttle body?
Old 06-12-2013, 12:25 AM
camaro75racer's Avatar
Default HSW 90mm plate with stock throttle body?
Ok i bought a used HSW plate and it seems to be the 90mm one. Is there an adapter i should use or do i just need a bigger throttle body? When i took the throttle body off and put them together there were gaps so apparently doesnt work straight off lol. If not then anyone out there have a smaller plate would want to trade with me?
Old 06-12-2013, 11:47 AM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
Do you still have the factory intake manifold on your car? If so i would be more worried about the step down after the plate more than the throttle body.
Trey
Old 06-12-2013, 01:44 PM
Nitro Dave's Nitrous Outlet's Avatar
If you are talking about the 2002 F Body in your signature and you have a factory 78mm intake the bolt pattern will not even line up. A 78mm intake and throttle body have a 3 bolt pattern. All the 90mm, 92mm, and 102mm have a 4 bolt pattern.
Dave
Quick Reply: HSW 90mm plate with stock throttle body?
