Every engine builder should have one of these
Old 06-12-2013, 12:44 PM
LS1Tech Sponsor
saccitycorvette's Avatar
Default Every engine builder should have one of these
AlignIt Tools are used to align the Rear Main and Timing Covers and install the seals!
Whether your a Pro or a Do Your Own Repair kind of guy, here is a simple but very effective tool to help you make
easy work of installing your LS1-2-3-6-7-9- LQ4-LQ9- 5.3-6.0 and all GM v8's from 1997-2013 Timing and Rear Main cover and seals. Works with all LS based engines!
Here is a couple simple but very effective tools to help you make easy work of aligning your Timing and Rear Main Covers. CNC Machined to exact tolerances, the AlignIt tools
get the covers centered perfectly with the crank. The O-ring design makes for a perfect snug fit no matter the temperature that can cause expansion/contraction of engine covers, crank & tools
that will hinder a perfect fit. The O ring design eliminates this problem. After the covers are centered and torqued down, use the AlignIt Tools to install the seals in seconds!
Available in the Pro Series 6061 Aluminum Anodized and the standard PVC Plastic. Both are CNC Machined to exact specs
from Billet materials.
www.saccitycorvette.com/AlignItTools.html
If you're doing a Rear Main Seal or Engine Build, its a good time to start keeping unfiltered oil out of your bearings and lifters! Check these Billet Oil System Improvement parts out!
https://www.saccitycorvette.com/OilS...provement.html
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 06-12-2013, 09:07 PM
PowerAdder's Avatar
Good Idea!!
Old 06-12-2013, 10:36 PM
LS1Tech Sponsor
Thanks PowerAdder!
__________________
Old 06-12-2013, 10:59 PM
sjsingle1's Avatar
i want 1 !!!!!!!!!!!!!
Old 06-13-2013, 11:36 AM
Boostedhatch's Avatar
how long on the rear main so i can get both?
Old 06-13-2013, 01:38 PM
BoostinIx's Avatar
Plan to run a package deal for both?
Old 06-13-2013, 09:00 PM
bobyboy101's Avatar
I'll have to pick these up next payday.
Old 06-13-2013, 10:25 PM
sjsingle1's Avatar
package deal !!!!
Old 06-13-2013, 11:08 PM
WSLN 6's Avatar
In for the package deal, just ordered the front tool......
Old 06-19-2013, 01:54 PM
LS1Tech Sponsor
Originally Posted by sjsingle1
package deal !!!!
Yep!
__________________
Old 06-19-2013, 02:09 PM
BoostinIx's Avatar
Well that's nifty
Old 06-19-2013, 11:05 PM
RedMan*'s Avatar
Just ordered the set.
Thank you,
Stu
Old 06-20-2013, 06:54 PM
LS1Tech Sponsor
Thank you,
Stu
Thank you Stu, for your business, we really appreciate it!
__________________
Old 06-27-2013, 11:53 PM
RedMan*'s Avatar
Fast shipping for sure.
Package was here when I got back home from picking up my L-33
Thank you Sir,
Stu
Old 06-28-2013, 01:46 PM
LS1Tech Sponsor
Thanks Stu!
__________________
Old 06-28-2013, 10:44 PM
WSLN 6's Avatar
Got the rear one too, looks great!
Old 07-01-2013, 01:32 PM
LS1Tech Sponsor
Thanks WSLN 6, appreciate the business!
__________________
Old 07-17-2013, 04:27 PM
RONIN LSX's Avatar
Anything for the cam install to make it easier? I heard of horror story about installing them and nicking the lobes. I never installed one so I have no idea.
Old 07-19-2013, 08:27 PM
LS1Tech Sponsor
Sorry, nothing for the cam yet.
Christian
__________________
Old 08-08-2013, 09:26 PM
glocklimited9's Avatar
I have both front and rear covers and ive used them multiple times so far..
Awesome product, and an excellent deal, all you guys who say you dont need them have to ask yourself why GM has a tool to do exactly this for about 8 times the price
They work great guys, thanks again
Quick Reply: Every engine builder should have one of these
