What paint to use on ls1 intake?
Old 06-12-2013, 12:50 PM
Turboswede's Avatar
Default What paint to use on ls1 intake?
I want to paint my ls1 intake and wonder if I can use just regular spray paint or do I need to use heat resistant paint on it?
Old 06-12-2013, 12:52 PM
Rise of the Phoenix's Avatar
You can use regular spray paint because the intake doesn't get that hot. There are tons of threads about this, plus if you search, there are several that give step by step instructions on how to do it right and dictate what supplies you'll need.
Old 06-12-2013, 01:14 PM
thunderstruck507's Avatar
I sprayed mine with satin black Krylon. Not even the fusion stuff...just regular old spray paint. No primer, no sanding, no prep other than a degreaser bath.
Old 06-12-2013, 07:17 PM
Blackpanther99's Avatar
Regular paint will be more than enough.
Old 06-12-2013, 07:25 PM
11SECSS's Avatar
Just make sure to get as clean and grease free as poss before painting.
Old 06-12-2013, 07:38 PM
Zlow28's Avatar
i sanded my ls6 intake, painted it with just regular paint and added a coat of gloss finish. heres what it looks like.
Old 06-13-2013, 01:59 AM
99Bluz28's Avatar
I like to use Dupli-Color Engine Enamel paint in the engine compartment.
Old 06-16-2013, 11:34 AM
meine96ws6's Avatar
i also used the high temp paint from a rattle can, a few light coats and its done...
Quick Reply: What paint to use on ls1 intake?
