turbo 5.3 transmission that will probably never see track
Old 06-13-2013, 07:19 PM
samtodd's Avatar
Default turbo 5.3 transmission that will probably never see track
Building a turbo 5.3 shooting for 600 rw max.. My plan is to build a DD that will probably never see the track or extremely sticky tires.
More then likely the combo will be something like a stock 5.3 t76 in a 3800lb car. I would like a overdrive transmission and this is a fairly tight budgeted build so Im assuming a 4l80e would probably be the way to go but wasnt sure how long a 4l60e would last driving like you stole it with no track time?
My concern with the 4l80e is loss of power and weight but Im not into changing transmission every other weekend either.
What you guys think??
Old 06-13-2013, 07:38 PM
1fast bird's Avatar
A 4l80 in stock form will hold good power and even more with minor clutch and shift kit upgrades. Would be my choice if it were a mostly street driven car no matter how much weight it might add.
Old 06-14-2013, 06:30 AM
samtodd's Avatar
That's kinda what I was thinking. Probably be the cheasest overdrive option I'm sure too. Thanks for the input.
Old 06-14-2013, 02:24 PM
LS1NOVA's Avatar
4L80E with Transgo HD-2 reprogram kit. Mine has taken a beating and hasnt missed a beat. The 80E shifts much much much nicer than a 60E.
Old 06-14-2013, 02:26 PM
samtodd's Avatar
cool thanks! And its my understanding that I should be able to control with the 5.3 pcm no problem??
Old 06-14-2013, 05:35 PM
Blackpanther99's Avatar
80e no doubt.
Old 06-15-2013, 06:25 AM
LS1NOVA's Avatar
Yes, you will need a segment swap for trans control OR a wiring harness mod that involves a relay or two to use a 60E tune.
Old 06-16-2013, 02:22 AM
badhombre's Avatar
80e and don't look back. I like my th400, but wish I had overdrive. an 80 is in my future
Old 06-16-2013, 03:38 AM
Nitroused383's Avatar
T56 for a street car, in my opinion their is nothing more enjoyable! Hold quite a bit of power with a few of the right parts and a good clutch (RXT).
Quick Reply: turbo 5.3 transmission that will probably never see track
