Do you think this tire is repairable?
Old 06-13-2013, 08:08 PM
Donohue96M6Z28's Avatar
Default Do you think this tire is repairable?
Was driving home and noticed that the rear was a little loud. Pulled over and noticed a huge screw in the tire. Do you guys think the tire is repairable and SAFE if it is repaired? I'll get it fixed tomorrow if it is. If not, I'll order a tire right now.
Thanks guys!
Patrick.
Old 06-13-2013, 08:12 PM
kciaccio's Avatar
I have done it with self plugging no problem. No slow leaks either. My hole was even bigger, it was the bottom leveler of a washer or dryer or something went into my tire. Will take two plugs possibly but I did it with no issues.
http://s3.amazonaws.com/cooltools_legacy/tire-plugs.jpg
Old 06-13-2013, 08:47 PM
buddhaz06's Avatar
Yes it is
Old 06-13-2013, 10:02 PM
SparkyJJO's Avatar
A tire shop should be able to fix that. The proper way would be to dismount the tire and patch it from the inside. Smaller holes can use those repairs that you push in from the outside, but something that big I'd want an inner repair done.
That bolt isn't at all pointy, surprising that it punctured like that. I had a big old bolt in my truck's tire, but the end was rusty and pointy so it easily poked a hole.
Old 06-13-2013, 11:58 PM
67goatman455's Avatar
our tire shop next door has done both the patch and plugging. they never do patches anymore unless by customer request. the patches will have a fault 2/10 times where as the plugs only have faults 2/100 times. plug is the way to go.
Old 06-14-2013, 06:53 AM
ramairetransam's Avatar
yeah thats fine , plug and patch it .
Old 06-14-2013, 10:49 AM
I work at a dealership, and they told me its borderline repairable due to the size/location. What are your thoughts?
Old 06-14-2013, 11:07 AM
Rich-L79's Avatar
Perhaps the dealership is trying to sell you some tires?
kciaccio's Avatar
I think they are over cautious due to our lovely court system.
Old 06-14-2013, 11:42 AM
SparkyJJO's Avatar
Size I could see, but location? It is in nearly the best spot for a repair.
Old 06-14-2013, 12:24 PM
buddhaz06's Avatar
Plug or patch or plug-patch. I agree 100% with 67goatman
Old 06-14-2013, 06:01 PM
I bought a new one, I appreciate everyone's advice!!
Old 06-18-2013, 04:47 PM
LS1Tech Platinum Sponsor
rudytirerack's Avatar
It appears to be over an inch away from the sidewall so its repairable if it was'nt driven low. It should be plugged and patched. The problem is I can not really see the size of the hole so I understand the dealer recommend replacement. I see you bought a new one which is good piece of mind but this is for others searching.
Quick Reply: Do you think this tire is repairable?
