E85 + Turbo + Plug Gap?
Old 06-14-2013, 09:03 AM
1INSANEGTO's Avatar
Default E85 + Turbo + Plug Gap?
What would you recommend to start with. On high boost (20psi overboost set to 25psi) it seems I'm getting spark blowout. It's fine at low boost (10psi) with no issues.
Before it was fine under high boost and the car made 800rwhp. So no clue on why I'm getting this now. E85 hard on the plugs? I think my plug gap is at 23 now....
Old 06-14-2013, 11:09 AM
1INSANEGTO's Avatar
56 views and not one response.......
Old 06-14-2013, 12:32 PM
ghost-1's Avatar
run it around 18 thats where mine is at 16 psi. What plugs are you running?
Old 06-14-2013, 12:39 PM
bttlfed98gt's Avatar
NGK R5671A-8 out of the box
Old 06-14-2013, 01:27 PM
2000RATA's Avatar
I run Denso iridium plugs gapped at .025" on E85 with truck coils. No one wants to pay the money but I highway cruise, stop and go traffic in the city with a/c and no trouble. Even when its cool out. Heat range is 8 or 9 if they were NGK's.
Old 06-14-2013, 02:22 PM
LS1NOVA's Avatar
.020 here, had the same issue on anything over .025 at 18psi and up.
Old 06-14-2013, 03:57 PM
9sectruck's Avatar
Im at .025, 20psi, tr6 e85 and it loves it... Tried 7 and throttle response was night and day different
Old 06-14-2013, 04:07 PM
oange ss's Avatar
.028@15 psi on E85, TR6's
Old 06-14-2013, 06:08 PM
1INSANEGTO's Avatar
We are going to put it back on the Dyno to make sure it not lean, fuel pressure issue or confirm its a spark issue. I don't have a wide band in the car so dyno is the best bet.
I miss high boost
Old 06-14-2013, 07:21 PM
Cam72aro's Avatar
Here's an idea, get a wide band in the car. Any turbo car without one is a train wreck waiting to happen.
Old 06-14-2013, 08:22 PM
1INSANEGTO's Avatar
Yaaaa deal with that is I don't have a mounting location. This is not a mustang or camaro its a cadillac lol
Old 06-14-2013, 10:19 PM
Cam72aro's Avatar
I know it sucks, but I would find a way somehow. What if you have a fuel pressure issue, or something else that you could have saw on the wb before you went into boost and destroyed 8 pistons or a pair of heads. It also helps to diagnose problems like this.
Old 06-15-2013, 12:33 PM
CameronVic's Avatar
Bullet proof vests are heavy and cumbersome, but they have the potential to save lives...
oh, and I ran my NGK B8EFS right out of box. They didn't blow spark out even as I went all the way to 23psi and burnt a piston nearly in half!
Old 06-15-2013, 01:33 PM
Sales@Tick's Avatar
I hope you are using a wide band on the dyno though right? Is it a eddy current or intertia dyno?
Old 06-15-2013, 02:11 PM
1INSANEGTO's Avatar
Well ya lol. It's a mustang dyno.
Like I said best thing to do is put it back on the dyno and check everything.
Old 06-15-2013, 05:35 PM
Johnv's Avatar
Valve Float can give similar symtoms, misfire at higher boost.
What valve springs you running ?
Also check all your plug leads.
Old 06-15-2013, 06:22 PM
Sales@Tick's Avatar
Well at least your getting a good amount of heat in the plugs on the dyno it being a eddy current dyno where load is placed on the vehicle.
Old 06-15-2013, 08:16 PM
86lxnotch's Avatar
i run BR7EF's at .022 gap on 20+lbs
Old 06-16-2013, 05:56 PM
1INSANEGTO's Avatar
Plugs are TR7IX gaped at .23
Quick Reply: E85 + Turbo + Plug Gap?
