2001 ecu, 2000 fbody flash and harness, which O2 sensors?
Old 06-14-2013, 10:20 AM
Sarg's Avatar
Default 2001 ecu, 2000 fbody flash and harness, which O2 sensors?
I was just curious which front O2 sensors I needed to purchase with the above combination of parts. I thought I read somewhere (can't find the thread now) that there were two different O2 sensors that fit the same plug but one will work, the other will not. I would like the ability to run in closed loop, but wondered which part number to get. Thanks guys.
Old 06-15-2013, 05:02 AM
Sarg's Avatar
No one?
Old 06-15-2013, 08:22 AM
bczee's Avatar
I have been ok with swapping or using the Rear F-Body O2 in the front.. as the wire are longer.. No problem so far.. as far as I know.. the only different is the length of the wire to the pigtail. (but I could be wrong).
BC
Old 06-15-2013, 08:35 AM
LS1Tech Sponsor
BP Automotive's Avatar
All of the Fbody cars used the same oxygen sensor from 1998-2002.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old 06-15-2013, 02:18 PM
Sarg's Avatar
But are these compatible with a 2001 Tahoe ecu? I just remember reading somewhere about a grounding issue and 2 different o2 sensors or something. Sorry I can not be more specific. I just remember one was effectively grounded by the case the other required an external ground wire but both would plug into the same pigtail.
Old 06-15-2013, 03:31 PM
oange ss's Avatar
doesn't matter, if the harness config is for an F-body and the PCM is set up for F-body then use the F-body O2 sensors
Old 06-16-2013, 08:38 PM
Sarg's Avatar
Cool, thanks. Hey you ever make it up to the year one show with that Chevelle?
Old 06-16-2013, 08:52 PM
oange ss's Avatar
not yet, one of these days
Quick Reply: 2001 ecu, 2000 fbody flash and harness, which O2 sensors?
