Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
PCV for my carb setup
Old 06-15-2013, 05:09 PM
silverls1z28ofdeath's Avatar
Default PCV for my carb setup
Ok so I'm sure this question has been asked hundreds of times. Buuut my question is that my motor pushes a fair amount of oil tho. So I don't wanna run all my oil through my intake and I'd prefer to not slime my engine bay in oil mist. So what do you guys think would be best for my pcv setup? Just wanna get some opinions or ideas. Thanks for any input fellas!
Old 06-15-2013, 07:53 PM
snook's Avatar
I run a couple breathers, and a pcv valve with a small catch can in line between the pcv valve and carb port. Im fixin to add a hole on the front of the valley plate and stick a breather on it
Just watch buying the cheap plastic air/oil seperators, lowes has metal ones with glass bowls on em
Old 06-16-2013, 08:35 AM
snook's Avatar
Saw these too
http://www.speedwaymotors.com/KRC-Po...tem,43118.html
Old 06-16-2013, 11:15 AM
onefast84's Avatar
I Just use a stock lq4 pcv in the valve cover with a autozone breather on the other valve cover. I does't use oil,or get it in the intake.
Old 06-16-2013, 11:38 AM
89gmcs15's Avatar
I've gotta figure out a PVC hookup too. Right now I've got nothing on either of the lines on the valve cover and I get a slight discoloration to the valve cover near the port after about 400 miles. Is this small amount normal?
Old 06-16-2013, 11:42 AM
snook's Avatar
It should be fine with just a breather and standard pcv setup. I just don't like the oil goin back in the carb. over time it will be yellow/oily in the intake, all that crap is goin back in there.
This is what Im thinkin of putting on the valley plate
http://www.summitracing.com/parts/knn-85-1221
Old 06-16-2013, 11:54 AM
Pop N Wood's Avatar
Getting oil mist in the intake is the same as lowing the octane of the fuel. You run the risk of detonation.
The LS1 method of putting the PCV valve on the valve cover is more prone to sucking oil. GM went to the valley vent and better baffling on the LS6 and beyond to supposedly reduce the problem. I run an LS6 style valley PCV set up, but still I have been meaning to put in a catch can for some time.
If you go the catch can route do a little reading and get one that actually works. The ones with wire mesh or sponge type fillings eventually saturate with oil and don't work as well as the ones that just mechanically separate the oil with a number of turns.
Old 06-16-2013, 12:15 PM
onefast84's Avatar
I also run a 1 inch valve cover spacer to clear my roller rockers. I think that this helps get the pcv farther from the oil. I theory anyways. Also wouldn't you have to use a hell of a lot of oil to lower the octane of the fuel?
Old 06-16-2013, 01:20 PM
newschool72's Avatar
I think it can have some effect on octane, mainly at high RPMs. My LS3 has the valley port and I run it straight to the throttle body port and have the small breather in the valve cover. Ive checked a few times and have yet to see any oil in the rubber hose , so I think the valley style PCV is pretty effective. Ive only got a little over 200 miles on my combo so far, though.
Old 06-16-2013, 07:52 PM
Were do you guys recommend to buy a oil catch can? Also is it ok to pull pcv out of one valve cover then just cap off the other valve cover. I only ask that since it would make it easier and more simple.
Old 06-16-2013, 08:16 PM
baronsmith98's Avatar
Who all has run a catch can with the stock lq4 pcv? I can really only find info on fuel injected systems. Would i just run from my pcv to the catch can to the carb and then run a breather on the other valve cover?
Old 06-17-2013, 10:39 PM
Bump for my second set of questions?
Old 06-18-2013, 06:56 AM
You have to let air into the engine to pull air out of the engine. PCV doesn't work without the fresh air source. Without fresh air coming in you can build excessive crank case pressure and blow gaskets and even push oil past the rings into the combustion chamber. Blowing the dipstick out is common as well without proper venting.
Old 06-18-2013, 10:17 AM
Doug G's Avatar
Mine is plugged on the right front and 3/8" hose from left rear to rear of carb. Seems to be fine so far.
My motor only pulls 11.X" of vacuum at idle.
Old 06-18-2013, 10:23 AM
89gmcs15's Avatar
I wish mine pulled 11at idle I'm at like 6 if I remember right. Is it worth it to put a catch can and PVC hook up on a bigger cam low vacuum engine?
Old 06-18-2013, 12:01 PM
LS engine s are sealed much better than the OL sbc, so It may not be as critical. LS engines are known for excessive crankcase pressure though, so a good PCV will help keep oil out of the intake or if you don't run a PCV at all, it will be all over the engine compartment. The crankcase has to breath.
On the vacuum, My SBC406 has about 5-6 ", but it doesn't matter because I have power nothing on it. Sounds like a Harley idling! The LS3 pulls a bunch of vacuum. I haven't checked it, but my brake manufacturer said It required 16" of vacuum for my setup and the brakes work great, even with multiple pedal pushes at idle. its crazy how strong it runs in spite of being mild enough to pull 16+" of vacuum.
Old 06-18-2013, 12:49 PM
Doug G's Avatar
[QUOTE=newschool72;17484224] On the vacuum, My SBC406 has about 5-6 ", but it doesn't matter because I have power nothing on it. QUOTE]
LMAO... thats about all my 406 SBC pulled with the XR292R cam and also power nothing....well maybe HP
Old 06-18-2013, 12:59 PM
Yep, Comp XE290S solid FLAT tappet, LOL. Old school all the way! Runs like a cat with a firecracker up its.... Well you know.
I will wind up putting an LS engine in it at some point, but I have the 72 and the 68 is in great running condition, as is.
Sorry about the jack ,OP.
Quick Reply: PCV for my carb setup
