cam install no start
I install a cc 306 and rocker in my 93 z28 now my car wont start unless I pump the pedal and then it stalls out when I let off the pedal. I need help
yes my check engine light been on since I deleted the egr but im not sure in any new codes. when I install the cam it started for about 30 seconds and it sputter out. I have checked the timing chain and the teeth matched up. will it start like that if one of the teeth are off?
check your grounds and throttle body and other gaskets and for vacuum leaks
look into the IAC Drill mod also
When I installed my cc503 it wouldnt run and idle till I drill the IAC hole a little bigger. then ran like a champ and ran even better after the tune.
and any other mods? stall? p&p intake/heads?
Village Troll
A tune will not fix a no start problem. Regardless of cam the car should still start. May not idle well, but it will fire. You stated you ensured you had spark, how did you do that other than putting in a new opti? Did you pull a wire and see if there was spark? You make sure the opti harness is plugged in? Was the opti easy to slide onto the splined shaft or did you force it on? You can get the codes by jumping some terminals in the data port IIRC. There should be more info on www.shbox.com
How about the valves, how did you adjust them?
an easier way to put it, did you adjust your rockers? a lot of people refer to that by saying adjusting the valves because thats what occurs when adjusting the rockers.
1 Post
I could be completely wrong but I thought that 93 was the only year that requires an eprom to be burned and installed on the PCM board. If that's the case he needs to look into a mail order tune where they can send him the chip. Again, could be totally wrong...
