Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Drive shaft
Old 06-16-2013, 02:35 PM
ejwmiller's Avatar
Default Drive shaft
Could someone tell me where to get a good drive shaft for a 97 Z28 I have a serious vibration with the car and it got worse with new ujoints could the yoke be off 180 degrees I noticed three drilled spots on one side like a balance factory drilling it looked like could that be off maybe
Old 06-16-2013, 02:43 PM
Blackpanther99's Avatar
Junkyard or give Bob at Brutespeed a call.
Old 06-18-2013, 05:02 PM
ejwmiller's Avatar
ok I went back and checked the u joints the rear ujoint was real tight so I tapped it on one side and it got real easy to move inside the bearing cups reinstalled and a lot of the vibration went away until I hit 55 mph then its gone at 60 mph then it comes back at 80 mph a bit more vigorous though is it possible the yoke is off 180 degrees as I didn't mark it when I took it apart would that cause a vibration as well? Any advice from anyone is welcome please I just got the car and don't know a lot about these vehicles and this is really annoying me I know the vibration isn't normal and I do know the rear end gear has been replaced from 3.23 to 3.73 and I almost think it could be in the setup on that how could I tell if it is
Thanks to any and all responses
Old 06-26-2013, 02:52 PM
OutlawDrifter's Avatar
give pst a call and get one of their driveshafts.
great company and product.
Old 07-23-2013, 03:22 PM
brigade24's Avatar
I would be tempted to check the balancing of the rear wheels...
Old 08-08-2013, 01:12 PM
ejwmiller's Avatar
sorry I took so long but I got it smooth as butter I bought a used aluminum drive shaft for 125.00 and even with the factory used ujoints it is smooth as glass now can't believe it but it did the trick
Quick Reply: Drive shaft
