power window issues
Old 06-18-2013, 04:17 PM
superlazy's Avatar
Default power window issues
Ok after a lot of reading I decided to pull the drivers side door apart and fix the issue of my window not going all the way up.
As the pic will show whoever replace the motor Farked up.
there is only 2 bolts and I'm not sure witch hole is for the 3rd bolt.
The other issue is even when I pull the window up all the way I cant get the left bolt to lineup correctly. do I need to pull the motor and start from scratch? Is there an adjustment I can make to get it to line up?
Heading out now for some JB weld hoping to get this fixed tonight
Old 06-19-2013, 12:18 AM
superlazy's Avatar
Well that was a Royal PIA!!!
Fixed but have do the fine tuning tomorrow.
Old 06-19-2013, 06:52 AM
Save the manuals!
wssix99's Avatar
The fix is in here. https://ls1tech.com/forums/general-m...-included.html
Old 06-19-2013, 10:12 AM
superlazy's Avatar
Originally Posted by wssix99
Thanks. That is the thread I was reading. Turns out the previous owner used threaded rivets that's why it fell apart. After about 8 beers I got it mostly done.
Not pretty but should last. Next will be dealing with the hacked up wiring job, but that can wait
Old 06-19-2013, 10:52 AM
Save the manuals!
wssix99's Avatar
If the washers are bonded to the composite panel, you should be fine.
Quick Reply: power window issues
