cts v fueling issues
i am working on a 2011 cts v, 85lb injectors, MSD BAP, and tuned for e85. The issue that I am running into, is that at idle, I am showing high fuel pressure(78-84psi) at idle. Any ideas?
Thats what we thought at first, called MSD and they said it was a bad BAP, so we got a new one. All wires correctly installed and it works like it should at WOT, just at idle its all fucky
msd bap have never really had a good track record... kenny bell would be the way to go..40amp version.
with that said..does your msd have an adjustable hobbs switch for boost? if its turned down too low ive seen them pick up refference from just the atomphereic pressure. could be ur issue.. but it will work fine at wot because ur getting 17 volts at all times..itll also cause the high pressure when idling as the voltage never goes back to 14
The MSD has a MAF sensor in it so it reads vacuum and boost. There is a vac line running the length of the car. The voltage will not drop below 14.2.
its at 660whp but on e85, 85# injectors
The MSD pump booster has a MAF sensor? No it does not.
MAF requires FLOW through to measure 'mass' aka density so it would have a MAP sensor or Baro sensor.
Running a Vac line to the location of the Voltage booster is a stupid design. kink in the line perhaps? Rule of thumb, Always use wire for signals... I wouldnt have bought this thing for that design alone...
PW is controlled in the ECM for pump. If you have removed the MSD out of the picture, the next place I would look would be the tune.
what are the odds that we would have gotten 2 bad BAP's? Like i said, this is our second one because the first was also bad.
Lets step back a step.
You are dealing with a PWM pump setup.
You are connecting to the FPCM not the pump itself correct?
I would have just upgraded the pump assembly itself ...drop in... so easy, many choices available.. remove all this voltage boosting all together.. but I guess that is here-say.
correct, we are connected to the FPCM then FPCM to pump. There are a ton of cars that are set up the exact same way that ours is, using the same parts as us, and work flawlessly. I dont get it
