12bolt?
Old 06-19-2013, 12:17 PM
ls1_johns's Avatar
Default 12bolt?
Hey guys so I'm thinking bout picking up an 12 bolt rear end rebuilding it and putting in my 2000ss any suggestions on what one I should look for? Any info would be much appreciated thanks again.
Old 06-20-2013, 11:03 AM
Formally Simplɘ Jack
BoricuaHec01's Avatar
Moser or Strange are good brands for 12 bolts.
Old 06-20-2013, 11:09 AM
alexus6798's Avatar
Make sure its a 12 bolt for an fbody not an old 12 bolt out a g-body from back in the day. If your are building it up, replace all bearings and gear and you should be good.
Old 06-21-2013, 03:37 AM
ls1_johns's Avatar
I was thinking buy an old school 12 bolt but cut the axle tubes off and weld the 10 bolt tubes on so over all length would stay the same then get 30 spline axles.
Old 06-21-2013, 08:06 AM
high impact's Avatar
Where are you going to mount the torque arm?
Old 06-21-2013, 11:00 AM
Fry_'s Avatar
If you want to build you own rear end like that look into a ford 8.8.
Old 06-21-2013, 11:09 AM
slt200mph's Avatar
You should consider a S60 or a 9 inch rear end. They will not break.
Old 06-23-2013, 02:54 PM
ls1_johns's Avatar
Well if I use the stock 10 bolt axle tubes then the torque arm mount should be close then if anything probably scoot in an inch or so
Old 06-23-2013, 07:29 PM
slt200mph's Avatar
The torque arm does not bolt to the alxe tubes it bolts to the center section of the 10 bolt...get under your car and you'll see what I'm talking about..you need to go to plan B cause your plan A will not work.
Old 06-25-2013, 11:57 AM
MikeWS6's Avatar
+ 1 on the 9 inch
Quick Reply: 12bolt?
