Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Crankcase pressure....
Old 06-19-2013, 07:27 PM
Doug G's Avatar
Default Crankcase pressure....
I seem to have too much crankcase pressure....blew out the dip stick, oiled down the motor and the track ....
I can only guess the motor needs more time to seat, and need to look for a catch can/breather combo ?
How much will this help ?
Old 06-19-2013, 07:58 PM
snook's Avatar
Should help, stick another on the tube too. I ordered one for he valley cover too, just gotta mount it
The stuff I used
The elbow for the tube on valve cover
http://www.oreillyauto.com/site/c/de...&keyword=46001
Use either end
small filter like yours (I have the filter off, but the tube is in the picture)
http://www.oreillyauto.com/site/c/de...ankcase+filter
The big one
http://shop.zzperformance.com/store/...-Breather.aspx
I took the filter on it and swapped it for a K&N breather though, it screws into the valve cover of all ls engines
The valley filter
Amazon.com: K&N 85-1221 Vent Kit: Automotive Amazon.com: K&N 85-1221 Vent Kit: Automotive
Old 06-19-2013, 10:33 PM
Prorac1's Avatar
Doug, I run a single 8an line to an allstar performance seperator/breather can. I have had no crankcase pressure issues at all. Eric L
Old 06-19-2013, 10:34 PM
Prorac1's Avatar
Oh. And what did it run? Eric L
Old 06-19-2013, 11:37 PM
lsxnotch's Avatar
Haha...^^^^this..
Old 06-20-2013, 04:54 AM
Doug G's Avatar
**** poor 11.79 @ 113
Never had this issue on the street and it's seen the limiter too....just needs to show its ugly head at the track
Old 06-20-2013, 05:12 AM
In-Zane Moderator
ZONES89RS's Avatar
Had my stock dipstick come out of the tube on nitrous, but it was planted into the engine tight. So is my braided setups I use now. The extra filter should help plenty if it is that bad id hope.
Old 06-20-2013, 07:55 AM
Doug G's Avatar
It was the first pass, I was nervous since this was a new combo and first time to the strip in 2 years I panic'd and short shifted 5500 and 6500
Old 06-20-2013, 12:13 PM
newschool72's Avatar
I wish I could remember the thread I read a while back on PCV on these LS engines. It was on LS1gto of all places. It was a link off the gto forum on LS1tech. Anyway the old guy that wrote it was a wealth of knowledge on the subject. I did mine roughly like he recommended and he claimed that, air in was very important for it to function right.
With a small breather on one valve cover, with a PCV valve in the other, or if its like mine, in the valley cover going to the engine vacuum source, you should be fine. You might get some oil in the intake and in that case, run a can , if its excessive. So far mine is working very well, but I think the valley port might be the reason I don't have any oil in the hose going to the intake.
What is your engine setup ?
Old 06-23-2013, 10:28 PM
3pedals's Avatar
Don't put a breather on the valley cover, I tried it, spewed oil everywhere. I now have 2 big filters, 1 on each valve cover, and no problems yet.
Old 06-24-2013, 04:33 AM
Doug G's Avatar
Pics....part numbers ?
I have a single 3/8" line going to the intake from rear DS valve cover
Dipstick itself came out....not the tube. I may mave other issues just too pissed to look at right now. 90* and high humidity isn't helping either
Old 06-24-2013, 07:30 AM
Like I said , Doug, If you are pulling air out through a PCV you have to have a fresh air source in , or everything gets in a bind. 3 Pedals sounds like he is running an open system without PCV and that will work. I ran that way on my 406 for a while, but adding a PCV to the back of my carb was the only way my dipstick stayed in. On the 406 I had 4 3" diameter breathers, 2 in each valve cover. It breathed good, to say the least!
Old 06-24-2013, 11:22 AM
nhra686's Avatar
If you run a vacuum pump, you can keep the oil inside your motor and out of your combestion chambers where it causes detonation and dead motors. If your motor is detonating, the knock sensors will pull timing and slow you down also.
Old 06-24-2013, 05:32 PM
Doug G's Avatar
Carbed, no sensors.
Looking at a few different filters now.
Old 06-24-2013, 07:06 PM
S10xGN's Avatar
I've got a pair of filtered breathers on my covers, got them from Jeg's in one of their closeout sales for < $20 each...
Old 06-24-2013, 10:26 PM
3pedals's Avatar
Doug I have HUGE filters on my valve covers. It is working, engine breathes and does NOT spew oil
Basically I cut the knock sensor tubes off my LQ4 valey cover and welded them to 2 pass side oil fill valve covers. I found 2 filters that fit .
Old 06-25-2013, 07:01 AM
Barrett, that's a wicked looking blow through set up! Is it in the car now?
Old 06-25-2013, 07:21 AM
3pedals's Avatar
Yes, only a couple shakedown passes so far, on pump gas, 5.5psi it went 10.77@131
I'm lookin for mid 9's on 15-16psi
Old 06-25-2013, 09:04 AM
Sounds very doable . Trap speeds on 5.5 lbs show low , low 10s potential.
Old 06-25-2013, 07:50 PM
Doug G's Avatar
Barrett, not too sure I have room for anything that size.
I have an idea or three and just need to mock it up.
Quick Reply: Crankcase pressure....
