92 GMC Typhoon T76, 4L80E, AWD, Forged 370
I have been working on the project for sometime now. There has been many many changes in directions along the way. Here's the Breaks down for the build being on a true budget. Over all go is
Engine
Lq4 block and crank
Eagle rods
Wisco dished pistons -25cc
04+ Z06 cam (budget)
next two i was at the right place right time and got them for a steal, damn near giving to me.
Crower solid lifters
Jesel PRO J2K SERIES full adjustable rockers
Z06 valve springs
LS9 head Gaskets
Arp mains
Ebay Head studs
LS6 oil pump
LS2 timing set
317 Heads cleaned up and milled
Turbo
Magnum T76 bb Q-Trim .96 A/R
Drive Train
Stock 2001+ 4l80E
Stock 92 typhoon transfer case
mated together with rpm adapter plate and input shaft
Stock rear end for now
Engine Harness
Current Performance
[IMG=https://imageshack.com/a/img707//su1r.jpg][/IMG]Uploaded with ImageShack.com
[IMG=https://imageshack.com/a/img96//qj6n.jpg][/IMG]Uploaded with ImageShack.com[IMG=https://imageshack.com/a/img37//qf0i.jpg][/IMG]Uploaded with ImageShack.com
[IMG=https://imageshack.com/a/img13//euw.jpg][/IMG]Uploaded with ImageShack.com
[IMG=https://imageshack.com/a/img547//o7ry.jpg][/IMG]Uploaded with ImageShack.com
Engine
Lq4 block and crank
Eagle rods
Z06 valve springs
LS9 head Gaskets
Arp mains
Ebay Head studs
LS6 oil pump
LS2 timing set
Turbo
Drive Train
Stock 2001+ 4l80E
Engine Harness
Current Performance
How much are the heads milled? With those pistons your compression is going to be too low in my opinion. Also I would turn around and sell the rockers and lifters, that is a solid roller setup and your cam is not. To me solid roller would be a huge waste without better heads and more compression anyway. Plenty of guys run stock or ls7 lifters and stock rockers with success. That's an area you could save money and put somewhere else like a custom cam........
I have a 76mm on a 346. Not all turbo's are sized the same. A tc78 turbo has a dinky 68mm turbine wheel unlike say a PT7675 with a 75mm turbine. That makes a huge difference as I choked the tc78 but the PT7675 so far has been fine up to 17-18psi on my setup. Need more fuel. My car is primarily street driven so I'm looking for response more so than peak power.
I had a similar build. forged 347, 02 LS6 cam, stock 317's with 79cc chambers = 8.7:1CR, twin T3/T4s, built 4L80e, Yank 3200 stall & made 603rwhp/600 rwhp on pump 93.
14psi.
It was slugglish out of boost but down right violent when in boost. If I could have done it over I would go 10:1CR + meth.
14psi.
The AR isn't the problem it's the physical size of the housing/wheel that are going to cause problems on that much displacement. The 370 under boost is going to try to move more air than the housing can handle. Think of it as trying to exhale through a straw. It might work well walking around but if you go for a jog you'll get backed up pretty quickly.
