Total timing over 20psi, whats everyone running?
Old 06-20-2013, 09:19 PM
driven87's Avatar
Default Total timing over 20psi, whats everyone running?
just got me to thinking about this the other day. im currently running 21psi and 15 degrees of timing. just curious what those run for total timing on cars running OVER 20psi.
Old 06-20-2013, 09:51 PM
9sectruck's Avatar
21psi 18degs on e85 going to 24psi and 16-17deg this sat at the track
Old 06-20-2013, 10:06 PM
SPRAYED 01's Avatar
Man so much more goes into this. Compression,cubes,turbo/blower size,fuel.
Old 06-21-2013, 08:31 AM
silverz28camaro's Avatar
I agree 100%
FWIW I was at 16 degrees of timing on 13 psi at 10.5 compression....I dont think I want much more timing on my setup on pump gas 93. Another important factor is whether or not you wanna spray meth/water.
When I data log my IATS I can keep them at 5-10 degrees over ambient UNTIL I make a pass, then they jump up to 140 degrees, in most tunes the computer will start to pull timing so you can loose another 1-3 degrees buy just the IAT falling into these cells.
With meth you can keep iats a lot lower in boost, and increase timing even more...
Old 06-21-2013, 08:36 AM
LS1Tech Sponsor
hellbents10's Avatar
Any where from 12-28* depending on the combo and fuel type.
Old 06-21-2013, 05:09 PM
MillsMotorvation's Avatar
16degree low boost, meth 9:7-1 comp.
Old 06-21-2013, 07:25 PM
LS1NOVA's Avatar
19* @ 27psi. 5.3, PT88, 10.5 to 1, E85
Old 06-21-2013, 10:24 PM
a4ls2goat's Avatar
16psi. 18*. E85
Stock 4.8
Old 06-21-2013, 11:55 PM
CameronVic's Avatar
Give the car what it wants, and don't fall into the trap of "timing envy". 10.76@131 in a 3700 crown vic with 16psi and just 13*. Non intercooled E85 and 50/50 distilled water and denatured alcohol.
So many things determine what timing your motor will like, and not one of the things your engine considers is what other people are doing.
Old 06-21-2013, 11:56 PM
CameronVic's Avatar
Oh, and quit with that ancient distributor talk. I don't even know what "total timing" is. Lol
Quick Reply: Total timing over 20psi, whats everyone running?
