Runs only with scanner plugged in
Old 06-21-2013, 09:28 PM
amerimuscle99's Avatar
Default Runs only with scanner plugged in
99 trans am on3 70mm kit
5.3 bottom end 243 heads ls6 intake
6speed
I have had the car done for 3 weeks now and I went to wire my wideband to the EGR. So I found the 5v reference cut it and spliced in my wideband. No worrys lol I go to start the car and ....... Nothing just cranks and cranks. Acts like it has a almost dead battery the gauges sweep volt gauge on dash shows 6ish volts. I checked the battery and was looking at about 12.5 volts.(I checked with voltmeter) I even replaced to alternator exciter wire and swapped the alternator and the battery from my 2004 silverado and ended with the same results.
Now I hooked up my handheld scanner while the key was on showing about 6volts. Surprise !!!!! The second I plugged in the scanner the car just magically woke up! Dash volt gauge showed 10-12 volts. Started the car and ran great not a problem. The second I unplugged the scanner the car dies and goes back to what it was 6 volts and no starting.
The codes that are in the car are P1635, p0405, p0103.Now the P0405 is a hard code and won't go away when I erase them.They all are there only if I clear them and start the car.
Now fuses are good and the OBD2 port shows 12.5 volts.
I'm stumped other than thinking the PCM is toast......................
Old 06-22-2013, 03:18 AM
joecar's Avatar
Your scanner is completing a ground... you have a missing ground connection.
Old 06-22-2013, 08:35 AM
Thought about that to and I'm going to look some more this afternoon. All of a sudden though? I did not touch anything but that one wire??
But I'll take a look and see what I see.
Anyone have all the grounds for the F-Body?
ThNks
Old 06-22-2013, 12:12 PM
LSX Power Tuning's Avatar
Yep, I had a ground wire break on the back of the head before and it did the exact same thing. Took forever to figure out and find.
Old 06-22-2013, 07:11 PM
Well ground on the back of the head was the issue!
Thanks guys
Old 06-22-2013, 09:34 PM
old93camaro's Avatar
had same problem like 6 months ago.... did not put the 3 wires back on the head
Old 09-22-2013, 09:58 PM
c-ham's Avatar
Back from the dead. So glad to see someone else has had this problem. My car will run but cuts off/ dies intermittently since engine install. I know the ground on back of head is tight, but I will be checking my wires tomorrow
Quick Reply: Runs only with scanner plugged in
