C5 dies on nitrous
Old 06-22-2013, 07:44 PM
fullmetalone's Avatar
Default C5 dies on nitrous
I'm spraying 150 shot on my C5. Only mods are Vararam, Ported LS6 intake and corsa mufflers. I'm running the dynotune kit controlled by a NOS window switch. When running the car on nitrous it will pull fine, but then die after the run. After cranking for a bit it will start up and run just fine, no issues what so ever. ECU isn't saying that it has ever had a lean condition. I have my WOT switch set to open at 4.2v on the TPS and between 3100 to open and 5800 to close.
There are my plugs.
Any ideas? I have found a few things that say you need to slow down with the car in gear otherwise it floods out. Which would make sense because the car will restart and run fine...
Old 06-23-2013, 03:21 AM
03EBZ06's Avatar
car will have same AFR condtions as plug in your hand when you let off. In this case, a little rich. Car dying is not a big deal, just roll it in 4th and recrank.
Old 06-23-2013, 09:43 PM
Car dying isn't a big deal?
Old 06-24-2013, 01:27 AM
03EBZ06's Avatar
just re-read your post. I see you car is mostly stock. Yeah, I would not really expect it to flood out and not want to restart right away.
Are you spraying before the MAF?
That first plugs seems to have a little more spark/heat than the second which is not unusual for a plate, but overall the AFR looks rich to me. I think this is contributing to your situation.
I would like to see a little more heat in the cylinder by leaning it a little.
Based on the first plug, may wanna take 1 or 2 deg spark out before doing it.
Old 06-24-2013, 09:36 AM
I'm running a plate system. Stock timing. BR7EF's. I feel like car dying is bad!
Old 06-24-2013, 09:46 AM
honguqia's Avatar
Not my taste but looks well done.
Old 06-24-2013, 10:42 AM
What? ^
Old 06-24-2013, 11:35 AM
HRHohio's Avatar
Originally Posted by honguqia
not my taste but looks well done.
^ spammer...
Old 06-24-2013, 03:48 PM
5.0 LsX's Avatar
there could be a big problem...I would start with pulling 4 degrees and then checking the plugs, and its probably going to want to go leaner
Old 06-24-2013, 04:09 PM
NSSANE02's Avatar
Stock timing? Stock Tune?
Make sure you have it jetted right and tune that ****.
Old 06-24-2013, 07:17 PM
Stock timing, stock tune. Made one pass on 150...car died and then started right up and ran fine, but didn't wanna spray again. Jets are as recommended .64 nitrous .38 fuel.
Old 06-24-2013, 07:25 PM
I'm going to guess this is in order?
http://www.racetronix.biz/customkiti...c=RFPK-007&eq=
Old 06-24-2013, 08:12 PM
NSSANE02's Avatar
A tune is in order. A wideband at the very least so you know what's going on. And you almost certainly need to pull some timing.
Old 06-24-2013, 10:32 PM
brett walker's Avatar
Probably just needs pistons lol. Serious note though, it needs a tune before you spray it again. Unless you want to put another short block in it. JMO
Old 06-25-2013, 04:48 PM
Nitro Dave's Nitrous Outlet's Avatar
You need to get it tuned. Odds are its rich. You are playing with fire not knowing where you are tune wise.
Dave
Old 07-04-2013, 08:04 PM
I ran it once on 150, beat a bolt on new 5.0 mustang by walmart lengths, and never did it again! I have it on 75 now, and runs well. Putting a racetronix in it, finishing up the exhaust and getting it tuned.
Old 07-05-2013, 10:25 AM
TA1364's Avatar
Definitely needs timing pulled, very good odds its way rich with those jets.
Old 07-05-2013, 11:48 AM
03EBZ06's Avatar
stop beating up on the tards. you got to beat an lsx to be legit.
Quick Reply: C5 dies on nitrous
