Commanded afr pid HELP
Old 06-23-2013, 05:28 PM
cfaluck13's Avatar
Default Commanded afr pid HELP
The pid that I have been trying to create to log afr err is not working, says 'parameter not supported' when I begin to log. It says the same for AFR command. Im just using [PID.6001] for the afr command. This is on a 2002 silverado. Does this pid not work on these ecms?
Old 06-24-2013, 10:19 AM
Bowtie316's Avatar
Did you add it in the table to be scanned, have to add it there first. I think its commanded afr high resolution or something like that.
Old 06-24-2013, 11:18 AM
cfaluck13's Avatar
Yeah thats what im asking, I add it to the table then when I start to scan it says "parameter not supported"
Old 06-24-2013, 02:22 PM
gagliano7's Avatar
Post up your scanner table there might be something your missing.
Old 06-24-2013, 04:59 PM
cfaluck13's Avatar
I'm on my phone now but I posted it on the hptuners forum here....http://www.hptuners.com/forum/showth...d-afr-pid-HELP
Old 06-28-2013, 03:27 PM
cfaluck13's Avatar
No one else has run into this?
Old 06-29-2013, 07:30 PM
decipha's Avatar
The pid name is eq_ratio its lambda inverted
Old 06-30-2013, 04:47 AM
MontecarloDrag's Avatar
When you get a <unsupported parameter> error, it means you aren't logging another PID which is needed for it to work.
What exactly are you trying to do?
Old 06-30-2013, 01:07 PM
Monte4ever's Avatar
Did you add to your histogram config in the plot section?
Old 07-02-2013, 12:27 PM
cfaluck13's Avatar
I just wanted to watch the arf command so I can create a pid to see the % error.
But the afr command does not seem to work therefore the error pid does not work.
Old 07-02-2013, 01:34 PM
There are built in PIDs for both, you don't need to create anything, just include them into the main table and start scanning
Old 07-02-2013, 02:59 PM
cfaluck13's Avatar
Yes, Ive seen them. When I insert them into the table they appear as normal, but when I start scanning they say 'parameter not supported'
Quick Reply: Commanded afr pid HELP
