5.3 s10
Bone stock 40k mile 5.3 out of 2004 avalanche. Comp 273lsr cam. Arp head bolts 799 heads cleaned up and shaved .20. Trunion upgrade and trick flow pushrods. Victor jr intake 650 Holley dp. JW 10 inch converter 3600 stall. Th400 3.50 gear. That's the complete run down.
25 hp difference between stock 706's and the 799's. I had the truck dynoed with both, and ran at the track with both. less then .1 difference ,On my next 5.3 I will run the 706's it not worth the change.
And as far as this 5.3 is concerned I consider it mostly stock compaired to the big and small blocks I've built in the past. stock gm short block, gm casting heads is that a more acceptable description?
I thought about tryin to pass mine off as cam only but it didn't feel right with the ls3 heads and a single plane and big headers lol. These things make incredible power for such little work that's for sure.
