Lowest profile 275 tire for 17 inch rim..........????
Old 06-23-2013, 11:39 PM
LS6427's Avatar
Default Lowest profile 275 tire for 17 inch rim..........????
I'm thinking if going 18x11.5 rear rims and 17x9.5 front rims. The 335/30/18 in the rear will have a small side wall......
Looking for the lowest profile 275 so it will match the profile of the 335/30/18 as close as possible......
Any suggestions you guys have. I tried searching tirerack but can't find the right numbers for width/profile/diameter to match.
Old 06-24-2013, 03:36 AM
99Bluz28's Avatar
With a 17 go with the 275/40/17, it'll only have .19" more side wall height.
Why not just go with a 18 x 9.5, and run a 275/35/18 ...?
Old 06-24-2013, 08:58 AM
LS6427's Avatar
You know what, I guess the only important part is the rear tire and traction. Wo cares what's up front, right...?
I mean, going to an 18" up front won't change the wet traction ability at all, right?
Old 06-24-2013, 11:59 AM
99Bluz28's Avatar
I've been running 275/35/18s for over 10yrs, and I seriously doubt you'll have any less traction than a 275/40/17 in a identical brand/model. Plus with a 275/35/18 you'll have a large selection of brand/models to chose from.
Old 06-24-2013, 01:06 PM
trans_am7935's Avatar
you will also be able to upgrade your front brakes with the CTS-V or Z06 brakes later if you wanted too. i think you would be much happier with 18's on all 4 corners. i am upgrading to 18's from my 17's just for the bigger brake and larger rear tire options.
Old 06-24-2013, 09:49 PM
LS6427's Avatar
Yup......you're right too. Or the big Wilwoods or MovIts I've been wanting.....
Old 06-25-2013, 02:17 AM
LS6427's Avatar
Do you happen to know which thickness spacers I would need for OE Wheels 18x10.5's.........widened to 11.5"
Brand...?
I know I'll have to do some serious hammering on the inner wheel wells. But will my normal LCAs be cleared by the inner tire wall? I really don't want to do a mini-tub.
Quick Reply: Lowest profile 275 tire for 17 inch rim..........????
