Pistons for spray??
Old 06-25-2013, 12:02 AM
lilmiller74's Avatar
Default Pistons for spray??
I am looking to forge my motor and im wanting to know if there are any weaknesses with running dome pistons with spray. my motor set up will be just a forged ls2 14.1:1 compression on e85 with alot of spray.
Here are this pistons that i am looking at getting, I will be taking the heads down to 64cc also to get my desired compression.
http://www.summitracing.com/parts/wis-k456x05/overview/
any advice will be appreciated
Old 06-25-2013, 01:45 AM
PONTIAC SLP's Avatar
As experience we sprayed 600HP on a Wiseco/Diamond custom has lateral gas ports without coating .
Old 06-25-2013, 02:18 AM
I dont know what that means lol, im just needing to know if there is a reason i cannont or should not use the pistons in the link. i am only going to be spraying a 250 shot at it.
Old 06-25-2013, 05:52 AM
I mean those brands hold up much HP nitrous , Those are good pistons , Why you want to run that high compression ? You want to run solid roller or HYD ?
Quick Reply: Pistons for spray??
