polishing headlights
unless your lamps are like,,,yellow i would use something less aggressive.
faethor's metal polish sounds interesting, or heavy compound..
just treat them like paint, they will look great!
I used 1500 grit, and it took me forever to get the haze and scratches out. If I had to do it again, I would go with something a little more corse, then finish with 1500 or 2000 grit.
Kevin
Kevin
I posted about two weeks ago on this exact thing. Mine were yellow and dingy looking and looked awful! I wetsanded first with 2000 grit but could'nt get it all off, so I changed to 1200 grit and it sanded much better. I then buffed them out with meguirs diamond cut compound which is some what aggresive buffing compound. The results was great, wish I had taken before and after pics to post. They dont look brand new , but the before and after difference is awsome and a whole lot cheaper than new lights from GM. Another suggestion, have a friend hold the light while you buff it, the buffer will grab the little **** and sling it!! Floyd
