Doing Header Install: Do I need a cherry picker?
I plan on taking on this endeavor in my apartment garage, facing inwards (towards the back, away from the garage door). Will I need to have a cherry picker to lift up the motor so I can replace the motor mounts and/or do the headers? I plan on doing the following:
*Headers (duh)
*Motor Mounts (poly's)
*Spark Plugs & Wires
I have 2 floor jacks and a car jack. Just not sure on jacking points of the motor itself. I already know I have to have the car higher than Lil Wayne on April 20th...
*Headers (duh)
Pretty sure you will need one if you're doing motor mounts. We used an engine hoist on mine and it was a pain in the *** because when we lifted it up it was being lifted slightly off center and it twisted the motor a fraction of an inch and we couldn't get the damn motor mounts lined up.
I did mine in my garage with jack stands and a jack. Just put a piece of wood on the oil pan and jacked the motor up a bit to keep it in place. One thing I didn't have an issue with though is the motor mounts lining up like everyone else does on here, I got the bolt halfway in before it stopped, so I just tapped it with a hammer and it slid all the way through on both sides. Good Luck!
You don't need one. I did mine with jackstands and floor jacks. Just use a piece of wood and jack it up like has been said. And definitely remove pedestals. Makes it a ton easier to line up. Also pay attention to how the mounts go in the clamshell. I ended up having to do one side twice lol.
