Pulled bellhousing, and TC stayed with the engine!
Old 06-27-2013, 06:43 PM
Calteg's Avatar
Default Pulled bellhousing, and TC stayed with the engine!
A little puzzled, everything I've read looked like the torque converter would come out with the bellhousing.
The three bolts that hold the TC on all have round heads...not really sure how to procede.
Old 06-27-2013, 07:35 PM
sreve's Avatar
Of coarse it will stay with the fly wheel if you do not unbolt it.
These round bolts.... allens?
Old 06-27-2013, 10:59 PM
LASTOFTHEBREED02T/A's Avatar
Lolz... sorry but this is funny!
X2, you have to unbolt the converter from the fly wheel.
Old 06-28-2013, 12:37 PM
spy2520's Avatar
If you are not saving the converter just cut the feet off. I've done this before getting the trans out of the car one time. If you are replacing the converter and flexplate i'd cut as close as possible and the bolt heads should just fall out. I used a reciprocating saw, you have more options since its out of the car and no trans in the way.
Old 06-28-2013, 01:33 PM
Moderator
mrvedit's Avatar
Yes, but check first to see if they are allen bolts.
Quick Reply: Pulled bellhousing, and TC stayed with the engine!
