Holley hi ram with a plate?
Old 06-27-2013, 09:04 PM
Lil'Felt's Avatar
Default Holley hi ram with a plate?
What are your opinions with a 102mm holley hi ram with a 102mm throttle body and 102mm nitrous plate pushing 200-250 shot of nitrous? Plan on pumping it through a 408 lq9 with port polished and milled 317 heads
Old 06-27-2013, 10:02 PM
PowerAdder's Avatar
Sounds Like fun!
Old 06-28-2013, 11:23 AM
Moderator
thechef's Avatar
get video......
that big of a shot I would be going direct port only.... with a stand alone fuel system
Old 06-29-2013, 05:42 PM
Lil'Felt's Avatar
I thought about direct porting it but with the plate systems out I feel they would be adequate either a plate or the new puck system. Want a nice budget nitrous/motor set up for my goat was looking for opinions from the nitrous guru's out there
Old 06-29-2013, 08:24 PM
Blackpanther99's Avatar
The new puck system is just for carbs isnt it? At least thats what Nitrous Outlet claimed on their new puck system I believe.
Old 06-29-2013, 08:33 PM
Lil'Felt's Avatar
I thought I seen then post it in their hi ram?. Guess I should do some more researching
Old 06-30-2013, 03:53 PM
brandon6.0's Avatar
maybe the spray bars? i wouldnt see why a plate couldnt do the job. People have sprayed 300+ on them with the correct tune up.
Old 07-01-2013, 10:05 AM
Nitro Dave's Nitrous Outlet's Avatar
200-250 should be doable on the plate. I would suggest reading the spark plugs to verify cylinder to cylinder distribution is looking good on the higher HP levels.
Another non direct port option would be to have us put a single spray bar down the center of the plenum.
Dave
Old 07-01-2013, 10:11 AM
brandon@nitrousoutlet's Avatar
You can run the puck with EFI. Just need a Carb-style intake manifold.
Old 07-01-2013, 09:01 PM
Lil'Felt's Avatar
@brandon what would you advise for a 200/250 shot to be effective a plate or something else don't am want to spend a fortune but if need be I will
Old 07-02-2013, 10:27 AM
I wouldn't be afraid of throwing 200-250 through a plate but you will be needing to check plugs pretty close to get your tune up dialed in. Have you heard of our Money Maker system?
Old 07-02-2013, 08:46 PM
LSXS10's Avatar
I really hope it works on 2-300 !!!! Then again I hope the stock longblock does.....
Old 07-02-2013, 11:12 PM
Lil'Felt's Avatar
I really can't wait to order these parts now, when do plan on running that set up? And are you running a ls1 or lq9 short block?
Old 07-03-2013, 12:36 PM
Ahh I see.
Old 07-03-2013, 10:42 PM
LSXS10's Avatar
If u were asking about mine it's a new l33 5.3...... Yes really. Hope to make a pass late summer. Not really sure how its Gona run in the truck but we see. Wonder if there is a stock bottom 5.3 n2o record? Lol...
Old 07-04-2013, 08:36 PM
brandon6.0's Avatar
LSX10 your setup looks killer with the holley intake. that is going to look badass in your s10. Let me know how it does on the plate? may consider something similar.
Old 07-05-2013, 02:41 PM
a98ws6's Avatar
How would the Hi ram compare to a Super vic and a plate?
Old 07-05-2013, 11:47 PM
LSXS10's Avatar
Thanks man... Ill get a thread together when I get a bit closer to finishing it .
Quick Reply: Holley hi ram with a plate?
