Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Check out SacCityCorvettes version of the Big 3!
Old 06-28-2013, 05:41 PM
LS1Tech Sponsor
saccitycorvette's Avatar
Default Check out SacCityCorvettes version of the Big 3!
Hi Everyone!
We have put together a Big 3 kit for you that is easy to install!
With all of the high-tech electronics that have been incorporated into your C5 Corvette, not to mention additional aftermarket electronics and stereo systems, it can take a toll on the factory charging systems ability to keep up. Especially if, over time, connections have become corroded.
Installing a BIG 3 upgrade can be very beneficial as many on the Corvette forum will tell you. SacCityCorvette has developed a BIG 3 installation kit for the C5 Corvette. It is made from all high quality materials and designed so it will not look like an aftermarket universal kit. For safety it has a 100 amp heavy duty fuse, uses automotive grade 4 gauge wire. (not the type car stereo shops use) The positive wires have a High-Strength Slit Corrugated Sleeving just like the factory wiring over them for additional protection and a factory look. All connections are hydraulically crimped and come with all the hardware needed to do the install. The installation takes about thirty minutes with simple hand tools. If you have doubt that this BIG 3 kit will make any difference in your charging system, please check out our test video below and see how the voltage increases when we connect it! Also see the Installation video below. Update: If you have an issue with your lights dimming when you turn on other power accessories, several people have reported that our Big 3 has fixed that.
Here is the link with all the info. http://www.saccitycorvette.com/Big-3.html
Side terminal $119.95 Top Post $139.95
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 02-12-2018, 11:55 AM
LS1Tech Sponsor
We have the new updated Big 3's in stock for the C5 and C6.
__________________
Old 06-02-2018, 05:21 PM
cmysix's Avatar
ended any charging/fan/voltage issues I've ever had 2006 LS2 corvette
Old 06-02-2018, 09:09 PM
LS1Tech Sponsor
Thanks for the update and your business cmysix!
__________________
Old 06-03-2018, 09:27 AM
cmysix's Avatar
Thumbs up
Sac City's products not only work, but they make sense and don't break the bank. I got more voltage at the gauge but more importantly the voltage does not drop when things start coming on like the fans.
Quick Reply: Check out SacCityCorvettes version of the Big 3!
