Absolute speed stg 2 5.3 heads with 978 springs ??? About settin up valve train
Should i need shims or not ? I am running stock rocker arms the heads are 5.3 l heads unmilled ... i started puttin the car back together last night with shims jay gave me but it just didnt seem right .. After tightening the rockers to 20lbs you could move the rocker arm back and forth with little force on the spring .... Without using the shim and tighting down the rocker with my fingers using a socket the pushrod was compressing down .... Are shims useally required for a unmilled head ? The only difference i can think of is i am using fel pro gaskets and i heard they are thinner
You should call jay, because i think the reason he gave you shims is because the valves he uses are longer than stock. I'm not sure if he does this with the stage 2 but i would call him
BTW .. he said no extra machining is done for these springs .. does this sound right?
Hope this helps ..
Crowley
