Hold 2nd for burnout
Old 06-29-2013, 12:35 PM
Monte4ever's Avatar
Default Hold 2nd for burnout
The title says it all. I'm trying to figure out how to get my 4l80 to stay in second gear when I select it in order to do a burnout at the track.I have Hptuners and don't see anything for that purpose. There's got to be a way cause I see it done constantly. Thanx in advance.
Old 06-29-2013, 01:23 PM
Monte4ever's Avatar
And yes, I'm totally new to this tuning stuff.
Old 06-29-2013, 04:02 PM
floman's Avatar
I just manually shift my down to 1st and start burnout and then manually shift up to 2nd and hold there through the burnout. Works on my 98 Camaro. Put it in D when you roll up to the line to stage.
Old 06-29-2013, 06:18 PM
got-a-ls1's Avatar
its in there. under general transmission tab. upshift d2 2nd upshift d2 3rd.. etc.
Old 06-29-2013, 06:19 PM
got-a-ls1's Avatar
if you have a 98 or a 99 i do not believe the option is there however
Old 06-29-2013, 07:59 PM
Jake's Performance's Avatar
It's OK to start in first, but you want to get into 2nd asap and at as light throttle/low tire speed as possible. WOT 1-2 shifts while spinning can cause sprag failure.
Old 06-29-2013, 11:09 PM
Blackbird-WS6's Avatar
Whats the best way to go about then?? What do you recommend
Old 06-30-2013, 12:14 AM
Exactly as I stated above.
Old 06-30-2013, 12:30 AM
Ok thanks. Just wanted to make sure.
Old 07-01-2013, 10:18 PM
Monte4ever's Avatar
I was looking at that. IIRC, my D2 is set high (300+). I guess that's to hold it in 2nd. I'm at work so I'm not sure of the numbers.. Thanx.
Old 07-02-2013, 12:36 AM
01ssreda4's Avatar
In regards to HPTuners you can do it with the scanner in real time if you have the laptop in the car.
Old 07-05-2013, 07:07 AM
Monte4ever's Avatar
Do what?
Quick Reply: Hold 2nd for burnout
