where do all of the "c" connectors plug in? trying to different route
I posted this in the camaro section figuring id get a hit from one of those guys but didnt have any luck.
Im wondering where/what do the "C" connectors on a ls1 fbody harness plug in?
Ive done truck ls swaps in the past using a truck harness and factory fuse block which worked great and would like to do similar with the fbody harness i have for my lq4 swap. I bought a fbody underhood fuse block hoping that the harness would plug right in like the truck one does but it doesnt seem like that is the case.
Id rwally like to do it this way so almost everything has its own fuse instead of like most "stand alone" harness they are only ran on like 4 fuses.
Anybody got any ideas? No local wrecking yard has any camaros for me to look at and like i said i didnt have any luck in the factory camaro section here.
LS1Tech Sponsor
The Fbody fuse block is completely different. I have some factory fuseblocks in stock. We also offer DIY kits for harness modification that are factory quality and compact for a clean look.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
LS1Tech Sponsor
I dont have them up on my website yet, but I do have them on Ebay. Here are the links. You have to wire it into your harness.
With Electric Fans and A/C
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=181113518001&ssPageName=STRK:MESE:IT
Without A/C and Fans
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=181167700132&ssPageName=STRK:MESE:IT
If you have a factory fbody harness I can make a plug and play kit to make your harness stand alone.
__________________
1-888-467-4491
1-888-467-4491
Can you further explain the plug and play kit to make it stand alone? My harness is a 99 fbody ls1 harness that ive played with the layout a little bit and deleted the emissions out of it. Feel free to pm me if youd rather not go into details here
LS1Tech Sponsor
Basically the Plug and Play Kit will plug right into the harness you have, then you just wire up the fuse block and the gauges. Everything comes labeled. Here is a member that had me build one that was customized a little.
https://ls1tech.com/forums/conversio...tch-build.html
__________________
1-888-467-4491
1-888-467-4491
