nos mini programming issue?
Had my nitrous kit installed last week. NO nozzle kit 150 shot, lnc-2000, nos mini, no fuel cell. On a c5z with 402.
my issues that all the noids fire and wiring seem to be right. My buddy who works a PSI in portland installed it all. Well went out today to test it out and would not spray. nos mini is all set up and programmed. using tps activation. but ripped on it and deff wasnt spraying. He says its all wired up to use channel 2 on the nos box. display shows 1 r when activated.
not sure where to go. maybe he wired something wrong?
i programmed both channels on the nos box. even did the tps parts on steps 8-9 on the programming. channel 2 in the only channel that will read on step 9. but when it says end it goes to 1 r on the screen. which means its active on channel 1 right. the wrong channel. how do i get it to activate channel 2 then?
I run the NOS Mini. I use both channels, one for spray and one to control my custom operating system.
Activate the hand-held, then write down all of the params and post here.
You did set the RPM to 4, not 8 right? Of course, how did you wire in the tach?
I want to help you but I don't even know where to start on this post.
Can you list all your settings through your programming.
When you press button number 2 and hold it how does the tach read out compare to the cars tach?
Where are you pulling tach signal?
What voltage did you save your TPS setting at?
Dave
Dave
Dave
Dave
