P0200 Fix
Old 07-01-2013, 07:10 PM
gollum's Avatar
Default P0200 Fix
My 2002 SS motor would sometimes run verybad and flood at idle. I had to rev motor high to clear plug #5. Scan showed P0200 code. Turned out I had a short. Wire bundle exiting computor was rubbing against sharp edge steel on fire wall. I simply pulled wires away from firewall steel lip and wiggled all wires going to injectors to fix problem. I also tapped on computor using rubber mallet and wood dowel. So far so good. I hope this helps.
Quick Reply: P0200 Fix
