clutch dragging, because of throwout bearing shim?
Old 07-02-2013, 11:46 AM
mr93ws6's Avatar
Angry clutch dragging, because of throwout bearing shim?
Hey guys, i recently installed a spec stage 3 into my trans am. ever since it has been harder than normal to get it into the gears. so i revved it up while in gear and with the clutch fully pressed, and i inched forward.
my question for you is, could this be because i did not install the included shim for the throwout bearing? the kit came with instructions on what to measure to know if it would be required, but like an idiot i decided to live dangerously and just threw it in without measuring... so before i go dropping my trans again, is there anything else you guys think could be the problem im having?
many thanks!
Old 07-03-2013, 10:26 PM
Josh18Fan's Avatar
It's quite possible! The shim will move the TOB closer to the pressure plate, allowing more travel which may fully disengage the clutch. Definitely measure.
Old 07-04-2013, 01:38 PM
mr93ws6's Avatar
Is there any thing else that could possibly cause it? Like I said, id rather avoid taking the Trans out again...
Old 07-04-2013, 01:42 PM
Jeremy@RPMTransmissions's Avatar
Have you bled the system out completely? Did you install a remote bleeder?
Old 07-05-2013, 10:48 AM
mr93ws6's Avatar
i did my best to bleed it, the petal felt preety good. but i decided to go ahead and drop the trans again... wish me luck!
Old 07-05-2013, 02:55 PM
SNLPerformance's Avatar
If they said it required a shim and you didn't install it or measure to see it wasn't necessary, then that could definitely be the problem.
Old 07-06-2013, 10:46 AM
mr93ws6's Avatar
well now im having an entirely different problem... ive got the trans off the bellhousing, but for the life of me i cant get the fluid line off the slave cylinder... i pushed in the little plastic retaining clip with 2 screwdrivers and it still wont come off! i dont suppose there is any trick you guys know that would help me in this situation would you?
i did a search around the site and cant find anything..
Old 07-06-2013, 10:58 AM
mr93ws6's Avatar
actually, in the event that i cant get it off, do you guys think i could just take out the 2 bolts that hold the slave in and just slip it off the trans?
Old 07-06-2013, 11:57 AM
jmd
jmd's Avatar
Yes, unbolt and slide it off.
Old 07-06-2013, 01:42 PM
therealcreeper's Avatar
it's sort of a tricky procedure with only two hands but generally to get mine off I have to use two screwdrivers and also give the line a good push in toward the slave to get it to pop out
I've seen it countless times on here with Specs having issues without the shim installed
Old 07-06-2013, 05:55 PM
mr93ws6's Avatar
well, currently on the re-assembling stage. This is why i ******* love this site. you guys have been a major help! so thank you again
Old 07-11-2013, 12:22 PM
mr93ws6's Avatar
just a little update, ended up not being able to get the trans in, so i had it towed to my buddies shop. i kept throwing out my arm because of the awkward angle, but it should be done in a day or so
Quick Reply: clutch dragging, because of throwout bearing shim?
