Jet hot 2500 coating
Old 07-02-2013, 05:35 PM
ws602's Avatar
Default Jet hot 2500 coating
Has anyone used this coating on their hot side,if so please list the good and bad
Old 07-02-2013, 05:55 PM
LS1Tech Sponsor
saccitycorvette's Avatar
Ive heard good things but never used it myself
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 07-02-2013, 07:52 PM
427's Avatar
I have it on my Chevy truck with single turbo. It has been on 1.5 years and still looks like when installed.
Kurt
Old 07-02-2013, 07:57 PM
ws602's Avatar
Kurt
do you have any pictures?
Old 07-02-2013, 08:04 PM
427's Avatar
No pictures. It was not done for looks, I was trying to lower the under hood temps. My truck is just a daily driver that also pulls a trailer once in awhile, not much to look at! I had the dull black top coat, but they can put any finish color on top.
Kurt
Old 07-02-2013, 08:38 PM
ws602's Avatar
Kurt
did you coat the turbine housing on the turbo or do just run a blanket?
Old 07-03-2013, 08:44 AM
427's Avatar
Yes, I coated the turbo housing. I now have no wrap on any pipes, over the last 10 years (165,000miles) I have used a few different wraps. None of them worked for over 1 year when I was in Michigan, the winter would kill it. The last one I had on (DEI) lasted less than 1 year, it was shredding. I had been towing the mountains a bunch in that time period.
Kurt
Old 07-03-2013, 03:12 PM
WS6HUMMER's Avatar
How pricey is this coating?
Old 07-03-2013, 05:56 PM
ws602's Avatar
65.00 a ft on down pipes and about 475.00 for the headers
Old 07-04-2013, 12:20 AM
Tirefire's Avatar
Kurt
How big of a difference does the coating have on temperatures?
Old 07-04-2013, 10:54 AM
427's Avatar
Not sure as I cannot measure it. I have wrapped the tubing and Y pipe for most all of the years I have driven this truck. In 2002 when it was new I did not have it wrapped, after about 1 year my coil harness was crispy and it blew a coil driver fuse. I replaced one coil and both harnesses and added wrap. The wrap lasts about one year, but protects my wiring under hood. Now the coating is not covered, and my temps are lower. I always had to wear a glove when checking my oil when towing because the dipstick was to hot to hold. Now I can do it without the gloves. I have a friend at Jet Hot, we have talked about doing some dyno testing while measuring heat. Not sure if we will ever do it, but it's on the wish list.
Kurt
Old 07-04-2013, 11:54 AM
ws602's Avatar
Kurt
How do you think the 2500 compares to the swaintech white lighting ? It's a 6 week wait on swaintech vs 5 days with jet hot
Old 07-04-2013, 07:37 PM
427's Avatar
I have never used the Swain coating.
Kurt
Old 07-04-2013, 10:28 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
Is it worth doing longtubes on a procharged setup?
Quick Reply: Jet hot 2500 coating
