More boost in higher gears?
About a month ago I finished my first turbo build on my '01 Silverado and am still getting used to the behavior of a turbo vehicle. One thing that I've noticed is that I will get more boost in higher gears using a constant boost setting. For example I will get 9.5psi in 2nd and then 12.5psi in 4th. Is this perhaps because there is more load on the engine in higher gears?
It's a single Turbonetics TC76 front mount and A2A intercooler.
Thanks
Thanks
IMO its only way to go to get good controller like eBoost2 etc. Can set limits, change on the fly and controls boost more efficiently. On that note I have been around turbo cars but in process of building my first so to get good answer listen to experienced people not me, lol.
I would have to agree, the waste gate either can not flow enough due to size or location. Controller will not help much if any.
The extra load of the higher gear and wind resistance is putting more heat in the exhaust and due to the heat you are getting a higher flow rate, so much that the gate can't get rid of the excess this excess flows through the turbine spooling it more.
What size gate, turbo, ect does the truck have?
Fix is to reposition the gate, get a larger one, or dump it to atmosphere if its not already. Good Luck
^This X3
