Lt1 parting out sale!!!
Category: Racing Parts
Price: $0
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): KY
Item Condition: Used
Engine: LT1/LT4, Small Block
LS Engine?: Non-LS Part
I have a set of TRICK FLOW HEADS #TFS-30400010, TFS-3042B010.the heads have guide plates. they were 1500.00 brand new 12 passes on them, 20hrs of idle time. Number 5 rod broke, number 5 & 6 valves have slight bend, needs replaced. asking $800. if interested email me. I still have the build sheet from trick flow.
I have set of Comp Cams Ultra Pro Magnum 1.6 roller rockers w/ polly locks. new they were $350. I will sell them for $250 and throw in a set of hardened push rods comp cams # 7608-16. description is CS 7.200 5/16 mag.
I have electric CSR water pump in the stock LT1 housing ready to bolt on $100
I have the cover plate for stock dist location with timing mark, and balancer for the carb swap or ignition swap guys out there. the steel hub, balancer is from PROFESSIONAL PRODUCTS, and the cover plate is gm performance parts. I will take $200 for this combo. I also have an extra steel hub snout from Thunder Racingfor extra $50.
