'99 stock ls1 rearend leak?
Old 07-05-2013, 07:03 PM
bluegoose177's Avatar
Question '99 stock ls1 rearend leak?
Just bought a 95% stock ls1 t/a a couple months ago. The past week I've been hearing a metallic noise underneath the car about every two seconds when coasting in 2nd and 3rd gear. Checked underneath as best as I could and noticed my rearend has a slight leak. Just need gear oil and a new seal or a new rearend?
Old 07-05-2013, 07:22 PM
White6SpdZ28's Avatar
Probably have to open it up to see if any of the gears are messed up. Not a difficult job. The pinon seal is prone to leaking. Mine did on my 10 bolt and I replaced the seal. Did ok for a bit then started seeping again. Upgraded to a 9in after that
Old 07-05-2013, 08:10 PM
Ok thanks, I'll check it out
Old 07-06-2013, 01:12 AM
Burken01's Avatar
Yes open your rear end pumpkin, there is a magnet on the other side of the cover... You'll know if your gears are shot out if there is a bunch of metal on it.. Plus it will be visual by looking at the gear itself..
If all is well, autozone sells new gaskets.. Use a little high temp rtv sealer on the gasket they give on both sides...
Old 07-06-2013, 06:30 PM
garygnu's Avatar
pull the filler plug and check for fluid level .some good mechanics can install a new pinion seal with the rear still in the car,if the ring gear and internal stuff looks ok.
Old 07-06-2013, 07:39 PM
Ok, thanks. Also I've done a little research today and usually bad rear ends have a constant grinding noise, right? Mine hasn't grinded at all, It just has a slow little knock. Could it be an axle? And what's the best gear oil to use?
Old 07-06-2013, 10:05 PM
DirtyBirdMKE's Avatar
Pull the cover
Check for meta on magnet
Inspect gears
Have someone put in a new pinion seal
put back cover with gasket and RTV
Use Redline 75/90 Gear oil (already has LSD Additive)
Quick Reply: '99 stock ls1 rearend leak?
