4th gear problems only when going WOT
So i have a consistent problem with the 3-4 shift in my car under WOT only. I have zero issues when casually driving or under light load from 3-4. Im trying to figure out if its a syncro or fork issue... I have a monster level 2 clutch with oem hydraulics with the drill mod. Kind of has me lost because the car shifts perfect except under WOT
Had the exact same issue with my car. took the tranny out to find out my clutch and pressure plate were both shot, on another note my pilot bearing blew up i and he shaft was floating back and forth by 1/4" i would check the pilot bearing.
Time for a rebuild ! my trans am done that once to me at the track ! I literally had to man handle that thing out of gear. my brother bought the car later and had the trans rebuilt it never done it again
Pedal feels great and im using brand new hydraulics as well. I use wilwood 600+ fluid and always keep it flushed... This is the best fluid ive ever used. Just sucks that all gears except 4th i can bang through... I assume a tear down is the only way to really figure out if its internal. Might just do a trans fluid change and see if that helps any.
