Rear end shift?? what the h....
Old 07-08-2013, 05:53 PM
Serioussn95's Avatar
Arrow Rear end shift?? what the h....
Hey guys wells i just mounted my Jegs pro stars 15x8 wheels with 295/50/15. While installing I noticed on the pass. side there was a 5/16 spacer? weird. I pulled the driver wheel off and there wasnt a spacer. weirder lol. Got the wheels on and they fit great. Went around back to see how the car looked from behind and noticed that the driver rear tire is about 2'' out of the wheel well more than the pass. side which is about flush. Can anyone tell me what the hell has happened here and what the solution is? stock 10 bolt, only thing the car has had done in the rear is Comp. 3 ways... Thanks!
Old 07-08-2013, 05:57 PM
FormulaTA327's Avatar
Sounds like the rear just needs to be centered, I think you will need a adjustable panhard bar. Not sure what you could do with stock suspension
Quick Reply: Rear end shift?? what the h....
