How to pick a motor
How to pick a motor
I would like to use a LS motor in my current project which is a 1950 chevy car I want this car to be a driver. So the question how to decide what gen motor pros and cons please was thinking 5.3??????????
Yes 5.3 would be perfect power plant. it will make awesome power with bolts on's. look for a L33 5.3 because it has the 799 heads.(243 truck heads ) With a good flowing 799 heads will leave you with the 5.3 you can also run boost if you would like on stock bottom end and get you well past 500+ hp on stock bottom end. The L33 came on the 05-07 silverado/Sierra
Yes 5.3 would be perfect power plant. it will make awesome power with bolts on's. look for a L33 5.3 because it has the 799 heads.(243 truck heads ) With a good flowing 799 heads will leave you with plenty of options with bolt on's to make good hp/tq. Choosing the 5.3 you can also run boost if you would like on stock bottom end and get you well past 500+ hp on stock bottom end. The L33 came on the 05-07 silverado/Sierra. Lq4-lq9 6L would be a good motor if you want to stay n/a if you want to build a budget 402-408 stroker the 6L block would probably be the best. With the amount you would pay for a ls1-ls6 or ls2 you can build a badass stroker or make plenty of power with bolt ons either the 5.3 or 6.0 block.
a 5.3 ls motor would work great .do you plan to use a ls fuel injection wiring system ,or do a carb set up ?elderbrock sells a stand alone intake ignition system .the truck intake makes good power ,you mite find a 5.3 for $500.I believe painless wiring has a engine harness for ls transplants.
