T56 VSS Function
T56 VSS Function
I jumped into the whole LSx thing with both feet. Stuck a 5.3 and T56 in my 1998 Ford F150. I used a stand alone harness. I have not worked out interface details with the speedometer so my Output Speed Sensor or VSS is not hooked up. Will this affect the performance of the engine? Does this sensor need to be hooked up to allow other engine functions to operate correctly?
So yes, keep the VSS connected to ECU.
