Huron Speed A/C Turbo Kit
Huron Speed A/C Retaining T4 Kit
-In-stock and shipping daily, no wait time!
***Kit has many of the same features as the already successful kit Truck Manifold kit, however obviously retaining A/C with the use of a C6 manifold and a truck manifold combination fitting through a Turbo K-member. Kit will require the use of a Turbo K-member (was built around a PA Racing Super Turbo K-member) This can be purchased with your kit for a great price, or separately.
Order direct from our website: HERE
Includes:
-2-piece hotside in 2.5” piping w/ T4 flange and 44mm Wastegate Flange
-2.5” V-band clamp for easy connection of 2 hotside pipes.
-3” 1-piece Downpipe
-3" Cold side piping from turbo to FMIC to Throttle Body
-MAF Delete pipe
-50mm Blow-Off Valve Flange on Cold side piping
-4" core front mount Intercooler
-All exact, specific couplers
-Extra exact couplers to run or not run the MAF Delete
-All exact, specific T-Bolt clamps
-F-body front mount intercoolers brackets
-F-body alternator & tensioner relocation brackets
-Hardware to mount Turbo, intercooler brackets, intercooler, alternator & tensioner relocation to vehicle
All piping made from 321 stainless steel, fully polished.
Advantage of using factory GM manifolds, no fear of aftermarket headers or manifolds cracking due to the turbo weight!
Advantage of having the Huron Speed customer service!
Requires Turbo, Wastegate, BOV, Oil Lines, Pusher Fans, Misc Hardware, passenger side Truck Manifold to use on drivers side, and a passenger side C6 Manifold to run on the passenger side to complete
Kit requires a Turbo K-member (built around the PA Racing Super Turbo K-member) and lowering or removal of front sway bar
***Already have a Huron Speed Single Turbo Truck Manifold kit and are interested in this A/C retaining kit? No worries, we have your covered! Also available will be our A/C Retaining Upgrade kit for all Truck Manifold kit owners! Included will be the following:
-Instructions on how to shorten one cold side pipe
This upgrade kit will convert your Truck Manifold kit over to our A/C Retaining kit so you can get the A/C back on your vehicle! We will also allow an exchange program to help keep your costs down as well!
Purchase your hot side only or A/C Upgrade kit: HERE
Huron Speed
Includes:
-MAF Delete pipe
Huron Speed
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
We can get you set up with a bare kit or a kit as complete as you like catered to your set-up and goals!
__________________
We have ONE complete package in stock with a Turbonetics 7875 Ball Bearing Turbo, XSPower 44mm WG and 50mm BOV (you choose your colors)
Check it out here: https://ls1tech.com/forums/parts-cla...l#post17537570
__________________
Thanks!
__________________
__________________
Have a kit with a Precision 7675 IN STOCK!
__________________
Back up! Another kit on the shelf ready to go, pick your turbo options!!
Purchase your package kit w/ Turbo + WG + WG + more HERE:
http://shop.huronspeedproducts.com/F...rbopackage.htm
__________________
__________________
Back up, who else needs a kit?
__________________
