Oil feed/return sizes and locations
Old 07-11-2013, 10:10 AM
70ssclone's Avatar
Default Oil feed/return sizes and locations
Where is the best place to put my lines? Also what size ? I have an lq4 with a retro Holley pan and a gt45 turbo
Old 07-11-2013, 10:16 AM
Thumpn's Avatar
your return line needs to be a free flow to the pan so try and go as large as you can, I run a 3/16 feed and a 10An return
Old 07-11-2013, 10:17 AM
Ferocity02's Avatar
-3 feed from the block above the oil filter, and -10 return into the pan right above the oil level sensor.
Old 07-11-2013, 11:06 AM
70ssclone's Avatar
There's two ports on the pan for an oil cooler is it ok to have one as the feed line as mentioned above and just block the other?
Old 07-23-2013, 08:45 PM
2165 Turbo Rail's Avatar
I used -4 feed from the port that the stock oil press sending unit is behind the intake on the drivers side
then a -10 return dropping in just in front of the starter on the pass side of the oil pan
Old 07-23-2013, 09:18 PM
BlwnZ28's Avatar
Question
i have the adaptor block that is pretapped bolt on above the filter running dash 4 to my s/c and returning to the front of my oil pan with half inch.. my s/c is in the front though so i would tailor your return to optimize flow path depending on where you mount your turbo. Mine is best at front cause it just drops straight down from my s/c. there are recent pics on my 6.0 swap thread of the line setup.
Old 07-23-2013, 10:18 PM
mrstepheneades's Avatar
I returned in lower part of timing cover. -12an size. Feed line by added a bung to port above oil filter. -4an size on that recommended by forced inductions where I bought my turbo.
Old 07-23-2013, 10:43 PM
fastsspr's Avatar
Question
How close is your -12an fitting in the timing cover from the balancer pulley ?
You have pics of it installed?
Old 07-24-2013, 08:47 AM
68 SS's Avatar
I am also running a -4 feed out of the oil cooler port with a -12 return in the pan right in front of the starter. To return on the passenger side in front of the starter you have to weld the fitting into the pan because a bulkhead fitting interferes with the oil pump pick up tube.
Old 07-24-2013, 09:23 AM
We threaded the pan and screwed the fitting in
Old 07-24-2013, 09:39 AM
Here ya go.
Quick Reply: Oil feed/return sizes and locations
