just swapped in a m6 second grinds?
I just got my m6 swap done about 2 weeks ago, I bought the trans used from a guy, showed me a video of driving and had "no problems".. but as soon as I got it in my car and tried it my second gear grinds... ill post up a video to show what its doin.. I did a monster stage 2 clutch, flywheel, and throwout bearing, tick master, pro 5.0, and short stick.. all that is different from what he had in his car.. let me know your opinions on what the problem might be, syncros?? thanks for your time chad
My Camaro did the same thing in 2nd and 5th. If you forced it in it was fine, just couldn't shift it back and forth. A aamco 2 hours away tried rebuilding it 6 times and on the 7th time of them pulling it I took it to Tick haven't had a problem since. Does it shift normally if the car is rolling? Or does it still have to forced in? If rolling makes no difference I would bet its a syncro.
