Here is my bass idea for my 2002 Trans Am
Old 07-13-2013, 03:53 AM
IrbyBocksnick's Avatar
Default Here is my bass idea for my 2002 Trans Am
Seriously thinking about going with the stealthbox on drivers side.
See if this sounds like it will work. Should be some good bass with all of that power running to the ten.
Pioneer also calls for small sealed boxes.
I do have a question on mounting depth. Which is at 6 11/16 inches.
I could wire that sub down to ohm, which is watt the amp can handle.
I don't have to have bone vibrating bass anymore. But I want something decent and punchy. How is the bass response in these stealthboxes? Better yet, how is it with a speaker that can handle lots of power?
Pioneer TS-W2502D2 10 In. Champion Series PRO Subwoofer
Champion Series Pro 10" sub with dual 2-ohm voice coils
Specifications
Sealed Box Volume: The sealed box sizes recommended by Pioneer range from 0.35 ft³ to 0.7 ft³; within this range the ideal size is 0.6 ft³.
Vented Box Volume: The vented box sizes recommended by Pioneer range from 0.6 ft³ to 1.2 ft³; within this range the ideal size is 0.9 ft³. The ideal port size for a 0.9 ft³ enclosure is 3" diameter x 3.75" long.
Single Reflex Bandpass Volume: The bandpass box sizes recommended by Pioneer range from 0.6 ft³ per chamber to 1.0 ft³ per chamber; within this range the ideal size is 0.8 ft³ per chamber. One 3" diameter x 8" long port should be used in an enclosure with 0.8 ft³ chambers.
Power Handling: The woofer has two 2Ω voice coils; each coil can handle up to 400 watts RMS (800 watts total).
This will be the amp pushing the ten.
Pioneer GM-D8601
Highlights:
mono subwoofer amplifier
300 watts RMS x 1 at 4 ohms (500 watts RMS x 1 at 2 ohms)
800 watts RMS x 1 at 1 ohm
CEA-2006 compliant
Class D amp technology
variable low-pass filter (40-240 Hz, 12 dB per octave)
wired remote controls variable bass boost (0-18 dB at 50 Hz)
preamp inputs and outputs
speaker-level inputs via supplied RCA-type adapters
fuse rating: 40A x 2
4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
11"W x 2-3/8"H x 7-7/8"D
warranty: 1 year
Old 07-13-2013, 07:29 AM
HioSSilver's Avatar
I would like a stealth box on the dr s also. Does anyone make a box like that with a built in amp for the sub?
Old 07-13-2013, 08:51 AM
DoubleMods I thought did.
Old 07-15-2013, 09:09 AM
mr. ws6's Avatar
try this setup if u want loud and clean:
get the box from here:
(non-sponsor link removed)
i used the kicker 8'' subwoofer...fits perfectly to the specs of the box
Alpine MRV-M250 Mono subwoofer amplifier
Alpine type-s speakers all around
since the car is a "hatch back" it sounds great..hopefully it works out
Old 07-15-2013, 10:11 AM
The minimum I will go will be a 10. I was just thinking that speaker is perfect for those boxes because Pioneer calls for a small sealed box. Then jam it with close to 1,000 watts. It should hit pretty decent and sound pretty clean being it is sealed.
Old 07-16-2013, 12:18 AM
Anyone ever run a ported 15 in a Trans Am or Camaro? If so, how did it sound?
Old 07-16-2013, 07:15 PM
Here is a site that will go one 12 but it's sealed.
Old 07-18-2013, 10:19 AM
tswiz'smaro's Avatar
Ive got a 10 inch alpine type s in a stealth box running on a 500rms alpine mono amp. it wont shake your bones but it hits really well!
Old 07-18-2013, 01:17 PM
I got a RF amp that goes about 900 wats rms in 2 ohm.
Old 07-18-2013, 03:04 PM
Avaric3's Avatar
I have a ported stealthbox holding an 8" jbl gto804 and it hits harder than the sealed 10" I had in the same box when it was originally sealed off. its punchier and weighs less than the 10" as well
Old 07-18-2013, 03:35 PM
Black_Z/28's Avatar
Where could i find a single 12" sub box to put in the trunk?
Old 07-18-2013, 05:01 PM
I found a site that sells a sealed 12 box in the cubby
Quick Reply: Here is my bass idea for my 2002 Trans Am
