new fox combo
new fox combo
started another build so check this out. tell me which will make more power in my fox. trying to find best combo to run 7.10-7.30 on motor.if anyboy got anything close let me know.
current setup
01 lq4 stock bottom end
comp xer273hr .581/.588 224/230 114
ls2 intake
ported and shved .030 ls6 heads
92mm tb
42lb injectors
combo 2
01 lq4 block and crank
07 6.0 rods and pistons with valve reliefs
cam- .595/.598 224/232 112
l92 heads (may shave .030)
gmpp single plane intake
holley 7500r 850 dp
msd 6010
combo 3
01 lq4 short block
l92 heads
.595/.598 224/232 112 cam
holley 750 or 850 dp
msd 6010
current setup
ls2 intake
92mm tb
42lb injectors
combo 2
holley 7500r 850 dp
msd 6010
combo 3
01 lq4 short block
l92 heads
msd 6010
I have vic Jr intake, and 6012 box. My cam is 622-600 231-243 at 111+3, my heads only milled .020. With 4.10 gear in a 3050-3100 lb car it has went 6.50 so far with ease. I let off on my last pass and lost 7 mph and still went 6.50, so its at the very least got some 6.45s in it. i would say with either carb combo, that should be simple unless your vehicle weighs 4000 lbs. LOL
